finish command
  • Thread starter Thread starter Hope
Hope
when they incorrectly select a big subax from the assembler, nx grinder for minutes and often close the application from the task manager because I have no visibility of how long it will take to "unlock". but I have to recharge the axieme. Is there a way to end a command (which is not a real command)? It would be quite convenient for the little experts like me :).
Have a good day.
on the home pc works! But I noticed that while on the student installation that I have at home there is also the classic stop command window, in that of the office does not appear. I'll try again on Monday.
Thanks for the answer.
ciao @hope known that the many of your posts, compare the student version with the commercial one.
from what I know there are no differences except in the possibility of saving or exporting to certain formats.
the two installations have exactly the same version / mp?
to me it seems that student and commercial in use must be the same.
thanks baskets and caps, in this case I was comparing the student version of the house with the strongly customized one of the office.
Sometimes different windows appear depending on what I do. for example as in this post, when the pc begins to grind because I have selected a large set, on the student version exits the stop command window while in the office no, but if I press esc as it suggested baskets the process gets stuck in all two versions (thanks for having suggested me baskets, saving an hour a day!)
I use 1984 at home, while I have to check for the office.
