moio92
Hello everyone, I have a problem that I can't solve and I need urgently because I have to deliver it as a relationship to support an exam.
" a square plate (lxl) is cooled with cylindrical fins (copper material). evaluate number of fins, diameter and length so that the amount of material used is minimal by switching a certain q power (please) "
then analyzing the problem I immediately said: the unknowns are three: No, d and l
I must minimize the mass of the fins, that is: m= (n ρ π l d^2)/4 where I will have to minimize only (n l d^2) (°°°°°) being the other constant quantities.
and I have only one equation, that of power: q=an h (ts-t∞) + n qaletta (°)
where an is the surface of the untapped plate and the qaletta is the power exchanged by an aletta, that is:
√(d^3) tanh(l/(√(k/(4) √d))
Now I thought of acting putting a certain value of n, through the equation (°) get an addiction between l and keeping all the other greatnesses as constant.
insert this dependence into (°°°°) , through the derivative find the minimum value of l (or d) and then repeat the path for various n until you find the minimum value.
the problem is: how do I get an addiction between l and d from (°) being a nonlinear equation in two unknowns? ?
Is that right for you as a procedure?
Thank you so much for your help,
