sara89
I use revit recently and I'm trying to figure out what are the quickest commands to use to build everything that is not a wall, a loft or a window.I don't have to do great things extremely precise.
a tilted beam with which I can control it? and a whim?
can you make the whole model using only the masses?(I don't care to have a model with the materials or a nice rendering..I have to make only the geometry of the building)
If I'm in the plant and hid a wall, then how do I make it appear?
have patience, the command seeks I have used it but with little results. thanks in advance
