giotama
having to use a tensile spring inside an oleodynamic actuator to lock it, they are looking for the various systems available for fixing the pull springs. are to be excluded a priori the work of end of the wire type hooks or rings and I would need to be able to adjust the preload of the spring itself. I have seen some elements that go into the spring's inner spiral that could already represent a good solution but I was wondering if there was anything else...
Does anyone have experiences in this kind of problem?
giotama
giotama
