ROCKING
Hello everyone my name is lorenzo and I am doing a job of reviewing a flag crane with draw for an exam.
my doubt is in the simplest link to build between column-ipe and column-tirant since in the project the column has a tubular profile.
in reality this has been made with an ipe-column welding with a sort of milling on the ipe so as to embrace the round profile of the column, while in the thief-column two handkerchiefs have been welded between the two elements.
Now, since I had to schematize the structure and solve it histically, I assumed the hinges in these two points.
I wanted to know if someone knows how best to connect the elements then using a bolted connection taking into account that weld two handkerchiefs on a round profile I don't know how feasible it is.
Thank you so much!!
Thank you so much!!
