flat repetition bend direction contrary
  • Thread starter Thread starter andreaf93
andreaf93
Good morning.
for the first time the following error:
I press that I started from a .step file (designed by another person) and converted the particular through the conversion into sheet metal.
everything turns out quite correct except that when I make the table, in the fold notes of the flat repetition, the sense of fold is wrong (instead of down should be on), you see taking into account the 3 central suns that should be closer to the left side as from 3d view.
I attach for your convenience the part file I did and a photo of my table mass.
You didn't realize you still have your body imported. eliminating it you will see that development is correct.
the reason for this error of interpretation I do not know how to tell you but
just to make me your own, did your conversion not match the original?
If I go to eliminate the imported body, I remove the conversion function as derived from that.
if you mean the differences given by the functions after the conversions they wanted. while if I compare the imported solid with the conversion I feel perfectly equal.
of course it should be eliminated after:
body lime function
or expending the cutting distinct, select the body and do canc
If I compare the imported solid with the conversion I feel perfectly equal.
to me does not seem; make a copy of the file where you only have the imported body without conversion into sheet metal and overlap together.
I solved the way you said by removing the body from the distinct cut. Thank you.
(there remains a strange thing as other files in which I still have the body in the separate cut do not present this problematic during the table).
