flattened round tubes with tekla
  • Thread starter Thread starter teklast
the behavior you indicated is really strange, is it not that by chance you copied or connected views manually in multidrawing?
No, it's something I never do.
I have been using tekla for several years, since it was called xsteel and this anomaly I had not lived it yet.
even, when the customer called me to ask me about the presence of the same brand on 2 different boards, on the phone I almost quarreled continuing to reiterate that this thing was not possible. ..I then raise "discover my head of ashes" in front of the evidence.
Well, an explanation will certainly be there, but I don't know which one.
From now on, I will take into account having to make a quick check on the tables at work completed to see that this can happen again.
so, to visually document the event, I show the strawberries of the tables of the 2 multidrawings bearing the same brand.
Good weekend.
Good weekend.
Hello teklast
Too bad you didn't renew your assistance, it would have been very interesting to understand what was due to this strange behavior since in all these years you never understood
Hello teklast
I have already explained in a previous post the reasons of my choice.
thanks anyway for the interest.
Hello teklast
an incorrect error in the model database could result in the above problem?
I don't know if a bug in the database could give you the problem, if you probably solved it.
I personally check and correct the database if necessary at least one/two times a week. The operation costs nothing because it only takes a few seconds.
