flood channel
  • Thread starter Thread starter geom.Silvio Pellegrini
good day I design with revit for a long time and I never placed the problem of the gravy channels. I've been seeing that sometimes I have plans with the gutter channels. but does revit have the possibility to insert some channels of gravy? or do I have to create them every time through an extrusion? ?
Welcome to the forum.
there is the special command: start>tetti>canale di gronda....
to the limit you have to create only a new family of profiles, besides those present in the archive
Hello, everyone! I have a question, so much to change, but are there rain curves? Hello and thank you
Maybe I didn't explain well. the pluvial that I use is about 10 cm from the wall while the eaves protrude 50 cm. how can I collect the eaves with the rain? Are there curves or should I give specific parameters to the rain?
Just go to the site of any supplier and you will have the geometric features that you need.... Otherwise, look out the window and mix one!
if you use the family of rains contained in the forum "freedoms of families and objects - of revit" placed by handwar, there are various parameters to manage distances ...
Hello, everyone.
I have problems with the insertion of the gravy channels on the roof of the "gabbiotto" of which I attached the file.
It's almost a day I'm freaking out. ..without reaching a solution but, at the same time, I refer to base on why this operation does not happen as from normality of this command on the other "south" gabbiotto and always present in the same file.
thanks for the attention and possible help and clarification
even to me did not put the gutters, I imported in the drawing my gronda profiles and there were no problems:finger:
probably the default grondaia does not find the reference profile:frown:
Hello everyone
I am accusing myself to this discussion on the gutters
I have revit 2015 and I have created the gronda with the appropriate command "tetto: grondaia" now I would like to join two grondaies created on two adjacent bonfires but I can't do it since with the joint command I can't select them.
Does anyone know if you can join them? ?
