fluent model where turbine p.e.a.c.e
  • Thread starter Thread starter titurbina
titurbina
the turbine p.e.a.c.e is a hydraulic turbine that works with highly innovative free fur.
you know where I can find tutorials on the network using fluent
to schematize and find the couple needed for a fluiddynamic verification?
Did you find anything? I also care about myself as something but I don't know how to set the parameters in fluent.. .
weapon
the problem is to find examples, tutorials in this regard, to power
construct both the model, but also the program in language c.
What do you use fluent / gambit?
What real design program do you use?
Bye.
hi I use version 6.3.26 of fluent and 2.3.16 of gambit but I also used the predicting verses... for cad3d use pro_e. I mainly would like to calculate the pair due to the fluid passage for a propeller or turbine... a very simple example...no complicated... I would only need a hand in the set of parameters in fluent... Can you help me? Thank you.
weapon
Your wind problem is mine for the turbine p.e.a.c.e.c.e. in the field
water, if you send me your e-mail I can send you the inherent documentation
a tutorials for the udf application.
