fold interrupted sheet
  • Thread starter Thread starter Aleee45
Aleee45
Good morning.
I wanted to understand if you think it is a problem to make a fold on one side of the sheet with the beginning and the end interrupted at a certain distance, as in photo. (I am not referring to the discharge but to the fact that the sheet continues straight)
the central fold would be about 150mm.
to be feasible I think it is, but does it involve extra costs usually?
to perform this z, it is necessary to mount only the prism and the measuring punch, (largo as the fold).
if to perform the angles at 90° you have the collision, it is necessary to bend with larger corners then retrace. no extra cost, it is normal bending.
so should there be a long punch exactly as the fold I want to do? What if they don't?
all bending machines have to fix the split tools, of various sizes, so as to obtain any length quota.
if you want to be lazy, when the chosen series does not come to measure, you can slightly space between them, without compromising the fold.
I think I understand what you're doing. Thank you. But I imagine that there is a minimum length to be respected if I want to bend like in my situation. If for example instead of being 150mm was type 10mm long, can you still?
the minimum standar size is just 10 mm, but if you want, you can also order a lower size.
each company must always be fully equipped for its bending needs.
this applies to both prism and punch.
If you only have to bend in your piece, instead of two, you should only use the measuring prism, the punch can be even longer, because it is influential.
