fold lines on sheet development.
  • Thread starter Thread starter xxfast
xxfast
Hello everyone.:smile:
in a technical office I made drawings of sheet metal parts with sw 2009.
on the development of sheet metal, in the drawing boards, I did not appear bending lines.
but how do they set up?
I couldn't figure out how to view them on the development of instrument palette sheet.
generally use sw 2011, but I find the lines already set.
I have never used 2009 but I create that under the heading "flat repetition" there is a snap off (hidden) to activate. . .
from the table, menu view view, check that the sketches.
Hello
marco
in my new job I have available sw 2009.
I could not see the fold lines on the boards, in the sheet developments.
I tried all the settings, read all the guide.
at the end I tried to change the preset cartilage when opening a new design and I used a standard iso a3 of sw.
everything works regularly, but I did not understand where the error is.
I tried to correct also from edit sheet size, but nothing.
Maybe it's better to remake new files for the company I work in.
Thank you 1000. I understand now.
How's what? first you said you understood (and solved? ).
then you always have the problem. evidently in those cartilages is not set that voice activates sketches. if so it is not the case of completely remaking the cartilages; just open the templates of those cards, activate the sketches from the menu view and save.
you will be set by default for the future.
Mar
Thank you samp.
I'll try and let you know.
the fact and that on a pc I use sw 2011 and I had tried to set the fold lines and it was ok.
instead of where I work now I sw 2009 and I realized that the problem is another.
I'll let you know... thank you.
Mar
Sorry, samp. But when you say you open the templates you mean?
I open a new design by selecting the paper mill in question, modifying and save as the right model?
I mean precisely the sheet pattern files with cartiglio, i drwdot. do not make a new design, open directly those files that you already have, support the changes you need and ask them to save them. from that moment will always be available with the latest changes, then yes when you create a new design.
Mar
if I have understood well to show the fold lines on the development in the table you have to make dx key on the view and activate the flag as in the image
Mar
problem solved thanks samp.
