by fusion of what material? It seems to me that the thickness does not allow to be obtained by fusion, even if in shell.difficult to do it well with bends
could be done with a first punching of the funnel on flat sheet and later central fold with punch with a cavity on which the protuberance falls.
looks like a commercial product then made in very large batches (google gives me as a result that it is a anti-rotation bracket of the cost of 0.60€) that could be obtained from press on mold or by casting with shelling machine
You're right, I wrote a shit. No shelling.by fusion of what material? It seems to me that the thickness does not allow to be obtained by fusion, even if in shell.
according to me of bending machine you can do; for the function that I imagine has that piece (type clamp for antenna poles), it could be fine even if it was made of only 4 folds to 45° (it would become a semi-octagon). then under a simple press (also a manual barbell), with a punch make the fun. the rest (the side wings) are normal administration for a bending machine. Of course, the holes must come out of the laser cut plate.You're right, I wrote a shit. No shelling.
the mold should be the best system in terms of production costs.
to obtain it by fold only if you make a few pieces and however between equipment, it needs a special central and one for the side folds, gear change and operator the costs are certainly not low.
Sure.according to me of bending machine you can do
mSorry I put an immagin I found online because I'm not in the office. was to give the idea, the request concerns only the ray fold, typical of these clamps
Sure.
perhaps what we see is only an example and the piece that must be done does not have the central funnel; Moreover to guess the reality of the demands is the standard.
Sorry, I didn't read.
