folder "font"
  • Thread starter Thread starter Daniele-san
Daniele-san
Good morning.
I've been looking through unsuccessful discussions, I need your advice.
the fonts used by creo are contained in the directory c:\..........\creo 10.0.1.0\common files\text\fonts
at every change version of creo (I don't know if it's a wrong procedure, definitely yes) I have to remember to copy the fonts I had added in the new fonts folder.
Is there a string of the config.pro or config.dtl that can allow me to direct the search of fonts in a "personalized" folder located elsewhere so that each new version does not affect the above issues?
Hi, see below if you can do it.
namedescriptiondefault value
pro_font_dirsets the default font directory (creo will load all fonts in this directory into the drawing regardless of the contents of the system and working directories).<creo_loadpoint>\text\fonts\</creo_loadpoint>
Hello fabietto,
I think it's what I was looking for, I suppose it's a string of the "config.pro"
correct?
Thank you
