folding indication advance steel boards
  • Thread starter Thread starter doking
doking
Hello, there's someone who uses advance steel, I have a problem with the table of the plates and the indications of the folds. In practice I happen to get the table always with the flip piece and the indication of the direction of fold "under"
I tried to change the table style but the only thing I managed to get was a representation with the flipped piece but the identical "under" indication so in this case too erroneous.
solved after a few million xd tests
simply, after creating the table and detecting the inaccuracy, return to the model and set the main element of the sheet concerned, save, go to document managers and force the updating of the table in question even if it is not highlighted as normally happens when updating the model. after that you will appreciate the exact layout of the table
