for those who use vault... i need help! !
  • Thread starter Thread starter bich
bich
Good morning,
I took the big step and took inv.2011 with its vault in the office,
now after installing everything for benign on the server and on the clients I was beginning to load the files on vault (which I had never used...) and I went into several problems, so if I find who wrote the various manuals contained in the installation cd I spread the face.. .
My problems are mainly two:
- if I load the files with autoloader does not allow me to use the unique names and consequently makes me a thousand copies of the various pieces in common between different projects I wanted to know how you did and how you do
- I tried to load a drawing in autoloader I made a modification extinguishing it from the vaul and now it does not allow me to archive it, it tells me restriction: to maintain the correct relationship between the data, it is mandatory to archive the modified project files with the appropriate program.
p.s. is there a tutorial a guide something decent where you teach yourself how to use the vault?? ? ? ?
1) open the vault: tools > administration > vault settings. "Apply unique file names"
2) extract and store always as inventor, not using the vault commands
Excuse me, but how do I do that? I know it will be the easiest thing in the world but I have the lard in front of my eyes I can't find the foreign command on inventor... I'll be hungry:... .
If you use the vault you must have a vault project active. at this point instead of using the "open" command uses the "open from the vault" command and he asks you whether or not to extract the file.
thank you ... found!!!!!! I'm really hungry now I'm going to eat!+
p.s.I had no active vault module :frown:
