forature multiple
  • Thread starter Thread starter Tarkus
Tarkus
Hello everyone,
I have a plate with a few hundred m8 holes arranged irregularly, once made the first hole/mask, how can I go to apply the same processing to the same holes without being to click them one at a time?
I thought there was an option like "apply to equal entities" or something, but I can't find it.
Can someone give me a tip?
use the menu of the "features" that analyzes the model by finding to es all the equal holes on which then do the same processing.
Unfortunately I have the program on the pc at work and I can't help you with some screen, cmq is quite easy and intuitive
with the visible model go into the tab of the features, button dx-nuovo-mappatura holes- from the sending and let work. at the end you find a list containing all the holes recognized. if you find more than one with equal characteristics you shorten them in the same line. you can put a limit to the max diameter you intend to map, I don't know if there is the minimum limit (never seen...). at this point with the dx key select the line that contains the holes you want to perform -new cycle with feature-kilometers of drilling-selections the cycle you want to apply. and this is the base.
Okay, thank you.
I did a first test and applied drilling to all the equal holes he found.
of course now comes out a few questions:
First of all it did to me the drilling path below, that is it reversed the z direction of drilling. Why?
and then, it seems that it automatically takes the depth of the hole (or the mapping) from the model.
If I wanted to make a shorter hole? is it possible to give an arbitrary value to the depth, indispensable for mapping?
thanks again for the availability.
As for the puncture sense I have no precise answer, I think it depends on how the pattern reads, you can reverse the holes by selecting with the dx button the row that contains the holes you want to reverse and click on "invert hole". depth you can change it from the hole cycle mask. in the feature tab, in the lower window you have the possibility to change the depths to your liking, this variation remains tied to the single cycle, does not affect the mother feature
