forced interruption of a processing
  • Thread starter Thread starter BLASTIFERO
BLASTIFERO
Hi. .someone can tell me if there is a way to forcefully interrupt a workmanship in progress?...I do an example: I did "move 3d" with the right button, I gave him the move and I clicked done. after 10 min he managed to make the change ( admit it was complex! If I could interrupt, I would have acted differently.... is there a way to do that?
Yes, you can. . .
download this zip, unpack it in a folder that isn't cocreate.
when you block a process or want to stop a precess running, launch sd_proc.exe.
the program identifies the process running modeling and stops it, allowing you to continue the work.
this in most cases. does not work on all processes.
After the launch of this program I recommend you a reboot of modeling, even if you could continue your work.
There is already everything in modeling without using eelables that you don't know what they do..... just go to the modeling installation manager, find a file called sdkill.exe. launch it from winzozz run with -8 option.
if you copy it inside the windows folder of your pc you can directly run the sdkill string -8
