forcing at altitude
  • Thread starter Thread starter GINOPILOTINO
GINOPILOTINO
hi guys, could someone tell me a way to change the value of a quota (I want to manually set a value that doesn't match the truth) in the draft environment? the version is 8.1.I believe you can do (in solid edge is quite immediate).
an early thanks
change - > annotation - > text
attention that however is not reversible, in the sense that if you want to return to having the associated quota you must recreate
what it means "although a little late" :eek:
this part of thanks you could also save her
please come for the next opportunity to ignore your request
If they answer you in less time better for you.
here there are no people paid to post answers, but users who help completely free other users as it is in the spirit of the forum .
:3559: 36_1_10:
Noooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo . I'm sorry if I didn't feel bad.
You're right, now that you've explained it is my duty to admit the misunderstanding
I apologize for my answer a little acid :biggrin:
...pretend your immediateness ? chimamamamama the hot line of siemens, if they answer you in less time better for you.
application at 08:55 , reply made at 09:50 .
... with all respect, but I don't think the line has reached these standards :biggrin:
hi ciciu, as you will understand my piccata response was following a misunderstanding.
I thought he was referring to my delay in the answer while he meant his delay in thanking...
as they would say to strip " that figure of mmm.. that I did ":hahahahah:
eheheh,
even the best always escapes something:biggrin:
Oh, sorry I'm late, you know:
eheheh,
No. 7 isn't there, I'll open a call or can you tell me where I can find it?
I use full menu advanced role, so I would say I have nothing hidden.
it is not on a separate menu, if you have a quote put in manual just that you double click on it (or dx edit button), then, always remaining above the quota redo button dx and find as last item in the context menu "convert to automatic"
Thanks axa.
I'm sorry I'm late for thanks and not stupidly trying the rmb.
Thanks axa.
Stop apologising! !
is a forum so each post when you can.
However it is not so immediate, I also had to go to the manual because I did not remember where it was:biggrin:
I'm using nx11 but I need to make a false quote. I looked for the command but it seems in this nn version there is. Is that possible? the tips above nn work, at least in the version that was installed to me. I am beginner and therefore I have greater difficulties than a user "fluent".
Thank you very much
Thank you very much
menù in inglese:1612955347467.webpafter you enter the field where you can change the text of the value of the quota
