formatting text in viewport
  • Thread starter Thread starter zetadierre
zetadierre
Good morning
I am carrying out a platform hypothesis for an exhibition, in which there are writings that run on monitors under a floor tramplable
I tried to insert the writings in the glossy design and then create a viewport, but change the orientation! How do I put them as I want?? ?
Maybe it's better if you write them as a record at the viewport. the writings turn according to the general settings > readable tipping text
the text is always oriented in order to be readable.
but you can convert it to polylinee and then position it as you want. :-)
This does not remove that, readable or not, I have not changed anything from one situation to another. I wanted to understand why the viewport result is different from the design, which should be subordinated to the fact that the text is set on the legible or not. but then apologize, but what does readable mean? I mean... You can't convert to polyline because you don't rotate... Come on.
also deactivating this option the writings are oriented by themselves the same
