DoctorBomber90
Good afternoon to all.
I would like to put some considerations regarding the freecad fem.
for the realization of a simulation on a certain model (which is static, thermal, electrical or vibrational) I have to:
- impose constraints;
- impose forces;
- meshare(create a grid on the model, which I will go to thread or not depending on what I want);
- choose the material;
- go to the command window, click on ccx_results, choose the type of simulation (if mechanical, thermal, etc.).
- What kind of bond does it impose? to see from the image put by me it seems of the incastri. I wondered if it was possible to impose different constraints such as hinge, support, skate (as happens in solidworks, ansys and other programs).
- Could you explain the difference between these two meshatura options (or grid)?
ie:the distinction between netgen and gmsh in what is it? - When I follow the iter from me described in the first lines of the discussion, I happen that, first choosing the material and then meshando the model (or the contrary), my model disappears (and the femmesh becomes stiff). Where am I wrong? that is due to the yellow-orange writing in the window "report"(low left)? first
after
in the command window
