I would like to ask and it is possible to make sure that a certain element, familgia or group are not editable, that is not active when I pass on with the mouse...
No. you can hide, but at the flow of the maouse they activate.
to not modify a solution may be to "make" a group and then block it, so that if you accidentally select an object (not to change) you appear "the notice" for the selection/modification of the group
