Guido
how do I determine the torque of clamping, diameter and number of bolts in a coupling between metal elements in order to avoid cracking (slitting and cutting of bolts) in the presence of a f force that tends to make "slide" one of the two components, considering a stable ??
I attached a sketch representing the application. the element "a" is stable while the element "b" is bolted to "a" . a force f tends to slide "b".
Thank you all.
Thank you all.
