from modeling to sheet_ problem.
  • Thread starter Thread starter piccio__87
piccio__87
Hello.
I press that the file originally is sheet metal, to make tests I added material and passed into "modelling" then I erased everything... now I can't go back to sheet metal, it's not the first time I happen, how can I proceed? ? ?
saluti..:frown:
your part has become a multibody, so no longer manageable as a sheet.
try to post the part
drag the end of the part to the beginning of the work, or you will no longer have to see anything in the model, convert to sheet metal and discover all the work. should work
ahia, then since 2011 including the problem does not exist... .
if someone knows the solution for my antiquated version 2010...... :(
I'll update! ! !
