Mouad
Hello everyone,
my name is mouad and I am a mechanical designer (design of electrogen groups)
use inventor 2017
I have an uneasy problem with a given engine in surface format that I can't turn into solid using the usual "join" command as I usually do
this I think is caused by the various errors contained in the design and certainly by the number of surfaces from which it is composed (more than 7000)
I am interested in turning this engine into solid because I have the urgent need to print it in 3d, since to print it I must export the file to stl format, the surfaces are not exactly displayed or at least recognized by that format.
I have seen many discussions about it but no one has solved my question
I apologize in advance if I place in a wrong place or unclearly.
use inventor 2017
