front-stop lamb
  • Thread starter Thread starter MaiMollare
MaiMollare
Hello everyone
I would like to fold a rectangular sheet in order to overlap the 2 extremities of 50 mm , I tried with the torospheric blend but coupled the sheet at the end without overlapping, my sheet will be + close to a spiral that to a bull. there is some solution thanks:finger:
hi, I don't know if this solution can suit you, because I didn't start on a flat sheet side but on a solid side:
1. a sloped surface of revolution; the height (1,1 in the example) you have to calculate it so that the surface at point 2 screws 1 turn+50mm
2. propeller surface
3. intersection between the surfaces (=> curve spiral) and projection on the plane
4. copy to obtain composite curve with extension of an extreme (0.1) to have a reference plan in the transformation of the sheet metal part
5. solid sweep and sheet metal transformation
allego the model in wf2
Hello cletus
you've got the problem and the system works, and I definitely wouldn't have come alone.
Thank you very much
