Alex37
Good morning to all,
we are doing maintenance to a department, and we have dismantled the machines to paint them with the occasion, now after having reassembled and tried them I agree to something strange, I press that are very simple, they have only two actuators, but they have a complex system of pneumatic valves.
on an actuator we use on both quick discharge inputs with silencer.
now when the machine finishes the cycle, after a few seconds, it feels that it starts to download the air from the silencer.
the resting actuator is not fed continuously with the air, it is only given a command for a couple of seconds and then stops, in this way having no more air in the air inside the actuator exits for the rapid discharge.
Is it normal that the actuator is not continually commanded at rest?
Thank you all.
Thank you all.
