function grapho cutting auger
  • Thread starter Thread starter feny
feny
hello to all... is there any guro that can help me with a tutorial or explanation to make a cutting coclea that follows a grapho?
Thank you very much
guru... not "guro". :biggrin:
Why do you want to do it as a graph and not with helical sweeps?
If you let us know exactly what you need (a hand sketch or a photo) ... some of us will be able to answer you.
I'm just gonna answer you right now. I attach you a right model for example...my doubt is...if you look at the model in the plant, as if I were the tool of the machine,(I also threw out the cut section) the cut that generates pro/e with the helical sweep, is the real one? is the heeling of the cutter tool during its progress to dig the channel with this feature? Could the grapho give me more clarity? If yes, could you explain how to do that I don't understand the procedure well?
Thank you very much
