fusion 360: import dxf file from autocad. i no longer visualize "point" objects
  • Thread starter Thread starter shadowmyth
shadowmyth
Good evening to all,
for work use autocad combination 2022 and fusion360. I normally imported autocad files, in dxf 2018 format, which also contained "point" objects that I need to center sketches over other sketch objects already contained or designed in fusion. I went back to work and upgraded fusion, but now I no longer see "point" objects when I amount dxf even though I actually have because I can select them. Besides, more problematic for me, I do not see those I go to put new ones with fusion on an imported sketch. Does anyone have my own problem and know how to get back to see them? Thank you very much for all the help you can give me.
