Lord Daz
Hello everyone
use fusion 360 for a few days is I find it a fantastic program! I am trying to create an undulating surface (a land) starting from a series of points.
on rhino it was enough to insert points to the desired heights, select them and give the patch command and a wavy surface was obtained.
Can you do the same on fusion 360? Can you explain how? as workspace select "patch" with the tool "point" I create so much points with different heights, but then I can't create the surface...where am I wrong? ?
Many thanks for the help!
