Saso93
Good evening,At work I came across a drawing on which this indication is present. We're talking about 2d of fried castings. In general rules there is an indication of the roughness of the processed surfaces, while in a separate pane I saw this indication in img.
I interpret it as follows: The removal of material in general is prohibited (except in the processed areas which are clearly indicated by a color code) and any manufacturing process of the component is accepted that guarantees a maximum roughness of 32micron (indication between quadre prentises).
is it correct or am I reading wrong? Unfortunately I do not understand this indication.
thanks in advance to those who will respond.
