general info on nx of siemens
  • Thread starter Thread starter marman
marman
hello to all guys I open this discussion to get some info about this software.
I'm considering a job offer where, I know for sure, that as soon as they find a fixed designer (which I could be so) they will pass to the nx of siemens (I believe and I wish the last version that is 12 if I'm not mistaken).
So I ask you, anticipately, how is this software I don't know. Let's talk about top-of-the-range software in the design field?or is it a mid-range program? is cad-cam or just cam?
I would like to have general information about this software.
Thank you so much to everyone who wants to give me some info.
Hello!
Hello, the latest version of nx to date is 1855. do not be afraid but have passed from a progressive numbering to a 'mensile' numbering.
nx is a top program and is used by fca, daimler, to cite some users.
It is modular-vertical in the sense that you can have perfectly integrated modules of cam, fea, mcd, and everything that goes behind it.
Good luck!
c.
by "variational" you mean that at any time you can go to change any 3d having always the list of commands performed previously and then modify them?
Absolutely.
not only on the "geometric" modeling, but also freeform.
...thank you so much drink now all clear... how are you with nx?it's complicated to learn... Of course there will be courses to do... .
It is not a complicated cad to learn, in my opinion.
a course done well, it is desirable, if not necessary, to work properly.
I think it is one of the most complete products on the market, to define it cad or cam is reduced.
I use it since 1993
by variation means that a cube can become a cylinder.
the system is:
timestamp order > means that 'works' (features) depend timely on each other.
parametric > i.e. all entities are editable by parameters
as mentioned above
Thank you so much... I hope I finally get the chance...
You've been using it for a long time.
Maybe......... never finished learning, it is one of the few products where the limit is the user and not the product
the system is:
as mentioned above
thank you very much baskets all clear.....gentilissimo. . .
hello and thanks again
