general table
MARCOC
Good evening to all
when I insert a general table on a table I have this problem
until I do the fields in the model that point to the columns of the tables, if I insert the model in the table the table updates me with the empty fields, and makes me disappear the display of the syntax
1 table without model picture
1642621871207.webpI insert the model the table with in fields of the 2 empty properties1642621855974.webponce completed data in the model correctly fill out the table1642622052057.webpfrom now on though if I delete the 3d model from the table the values in the table are not eliminated
and does not return the display of syntax
Can someone tell me why? ? ?1642622051973.webp(the fields update if I change the data in the model or if I insert a new model with other values)
Good evening to all
View attachment 64424I insert the model the table with in fields of the 2 empty propertiesView attachment 64423once completed data in the model correctly fill out the tableView attachment 64426from now on though if I delete the 3d model from the table the values in the table are not eliminated
Can someone tell me why? ? ?View attachment 64425(the fields update if I change the data in the model or if I insert a new model with other values)
did you try to make an upgrade or a ctrl+q, after eliminating the model?
if you put the table first and then the model does not work. I don't know why, but I do. proceed in this way:
1. put the blank table
2. connect the various columns to the props and put the first row with the headers
3. click on the table so that the menu of the same (you have to click on the top left of the table when the double arrow appears)
4. above you have the option to save the table: Do it
5. now open a new design
6. enter the views
7. insert the general table linking the table previously saved (I suggest to make a folder with all tables and link it to "file placement" from the settings, the gear you have at the top)
8. the table should auto fill out by linking to the part or the assieme
