generation frame sheet
  • Thread starter Thread starter cen82
cen82
someone knows if you essite the chassis generation function however where the profile that is used is a sheet, for example a profile to "u".
Obviously it is necessary to be sheet metal and therefore with its flat model.
Maybe you should publish the form you need in the library of the center so after you can frame it.
