give to each point its coordinates
  • Thread starter Thread starter stefano.a89
stefano.a89
Hello, everyone.
So, I have a problem, I find myself a drawing of a relief full of points detected.
Now, I'd like to assign his z to every point as a text.
example in my design I point: "101" and alongside his punishment (in space) I would like to make sure to select all points and have something like "101""234(cm)" "102""250"
I could change every point by reading its share in the property and insert it as text one by one but it really gets long for 2-300 points
is it possible to do it with a lisp or is there already a command?
If the text is a simple text not associated with the dot, it becomes a bit complicated, if I make a selection of everything, how do I understand which text to change? If you can, put a branch of the dwg, at least you have an idea how to operate.
bye
I'm sorry. .
I basically have this relief composed of only points.
I would like to be able to assign to each dot, a text with its coordinates (the quota is what interests most!)
I have the same problem as you!
the coordinates you can assign them with this here that I attached you.
I should assign name and quota after taking the points. but as was said before the text is not associated with the dot.
How to do that?
Bye!
