GeoTeo Guest Oct 22, 2009 #1 hello to all colleagues, looking for revit, railings made up of metal frames and between a pillar and other glass panels, know where can I find them? Thank you.
frcprogetti Guest Oct 23, 2009 #2 Yes, new > family > balasutra metrica-pannello. or try on revitcity or similar.
nirvana Guest Oct 25, 2009 #3 balaustre (a bit of suits genres), should be put as xche materials derived from 08 I think you need them to put them on the stairs. . Attachments Balaustre vetro.zip Balaustre vetro.zip 1.8 MB · Views: 586 GBRENU_Railings.zip GBRENU_Railings.zip 2.7 MB · Views: 302
nirvana Guest Oct 25, 2009 #4 ...old stair archives... there is one in glass, okay as a starting base.. . if you improve and update them to 10 (materials, notes, etc.) put them at your disposal. ...maybe turned to chicciola Attachments Railings.zip Railings.zip 7 MB · Views: 283
GeoTeo Guest Oct 27, 2009 #6 I can't just put the railing on the staircase, I'm standing instead of following the ramp, do you know how I can do it? Thank you.
gfrank Guest Oct 28, 2009 #7 select the railing - group modification> path change - group tools>modification host railing> - select the scale > end railing
