good plugin in the field of goldsmith?
  • Thread starter Thread starter cicala
cicala
Good morning, this is the first time I participate in a forum... I'm a bit excited.... anyway I want to explain why I'm here to write to you, I'm doing a gold-tech course where they teach me how to use rhinoceros for the creation of jewelry you'll have realized that they are at first arms... I have three thousand questions and doubts that pass me into my brain but for now I can't express them clearly. we start from a question I hope simple.. would you know to recommend a good plugin in the field of the ornament? Thank you very much
right observation, but given the neophylaxis of the post...... .
You may try to use the "research" command of the forum, this topic has already been dealt with in other topic.
Hello and welcome cicala
a good plugin in the field of the jewelry is definitely rhinoceros himself.
I'll explain. the various plugins found on the market are supported by the geometric engine of rhino and esentially
to speed up repetitive works, which cmq would be able to do with rhino but in longer times.
It is known that in the field of work time is money, spend less time so ago (in theory) earn more.
I see you're unemployed, so I think the time factor for now is not a problem.
the first advice I give you is to watch on youtube if you find video tutorials about jewelry
as in the link below where they explain how to make the attached image ring.
http://www.rhino3dhelp.com/tutorials/modeling-piped-ring-jewelry-in-rhino/The second advice I give you is to model, shape, shape, shape............ .
If you have specific questions, we are here to help you (as far as possible)
hi there are some rhino plugs, one is called t-spline and is useful for organic forms (flower leaves etc) the other is called 3dsmart and is very useful to draw the peas on any solid or surface:finger:
There are generic plugins such as arraycurveplus that can be applied to the jewellery industry, other specific plugins contain stone and prontuaries such as rhinogold or rhinojewel.
There are other free plugins like fathopper, which is able to create parametric forms in rhino.
at the base of everything there is always a good course of design, a lot of practice, another course, a lot of practice in an hour shop factory... and a continuous update.
to become good it takes years, plugins become only a help.
our plugin Stones For example, it's great for making stone disposition processes and doing all related nesting operations within rhino, operations that would otherwise be almost impossible.
... but they're even more impossible if you're not able to design a good object with rhino.
summing up: so much practice and so much study ... plugins can wait for now. :smile:
www.smart3d.net
Bye!
I have been drawing for years in rhino in the field of high jewellery... if you want, ask yourself. I read in the response posts and actually, more than that, I don't know what to recommend.
If you need a few tips, I'm here.
I also have a solidscape t66bt for prototyping.
alessandro - ac design
hi alessandro since you are in the field of high jewellery for a long time I have a domandina from ports, you know how to perform a perforation of a ring? I'll explain the strolls I've done: I would like to pierce the upper part of the object, I used the smash command to put in 2d the part to be washed, previously I realized a pattern with hexagonal forms I laid over the surface I made a bolean on curves to tell him the parts I wanted to keep full. I took the decoration and put it on top of the ring with the scorri command along the surface. Can you tell me? I mean, does the ring come with a few small hexagons at some point deform? Do you know another way to do that?? Thank you.
Bye!
I'm sorry if I only answer you now, but I've been out for a few days!
I don't understand your problem. What you want to achieve is the thread or outer surface of the ring? I usually when I have to orientate curves on a surface, first I unroll the uvs, I draw you on and then I reapply them! they are well, also calculating the type of surface you have. If there are subsquadri or elbows, the hexagons are deformed.
If you want to share the file I'll show you what I mean.
ac design
hi alessandro I answer you now because these days I have been engaged with the final exam of rhinoceros... . then the ring I made with double curvature creates problems... Anyway, I'll send you the file so maybe you give me some advice. I am aware that this ring could never go to a cam car.:smile: Thank you.
Bye!
the ring is an excellent realization, both from the point of view of the surfaces you used, and from the point of view of the feasibility.
Who told you it's not feasible?
I have prototipato coe much worse... ;)
If I can give you advice, work on the line of the stem to launch the line and lighten the ring.
never descend under the thickness millimeter.
Have you ever tried to create the ring exclusively from the wireframe of curves created by you? I am perfectly aware of the complexity of the operation, but I can assure you that you would have total control of the surface trend, you could give line to everything and lighten the visual impact. . .
I attach you a little finger seal I've done some time ago...the client gave me this marine water and asked me to make it according to a sketch...it could be useful to seize some guidelines.
for any questions... I'm here.
alessandro
I allowed myself to change your ring... I don't know if what you wanted to get comes close to this. I'm hearing some imperfections, but given the late hour... half my brain is already on the pillow.
The pattern you use is decentralized. ;)
alessandro
hi alessandro your words give me greater safety in myself ... after the course I should do an internship in company nowfa we hope well.. What you tell me is very fair I try.
Now I’m trying to make a pin, first I created it by free hand but bringing it back to rhino is another story... my little problem is the pavè this object is made all with this technique and I still have not understood how it is done ... thanks for the ring now I want to try to draw it myself on rhino...
Pave is the most complicated thing to do.
I did this:
I realized a sphere with a curve around (like planet saturno to mean us) and I grouped it. the outer curve represents the diameter of the stone, the ball is used to make the boolean to defer and to fdare to the recesser the point where to place the stone, facilitating the work to him and gaining in precision of the finished work.
with the command oriented to the surface, position the group so created in mnodo to create the pave '...you will have to start again several times, since it is difficult to find the perfect charm... but the final result is spectacular.
I'm looking for something I've already done and I'm putting it on.
alessandro.
p.s.: Good luck with your internship. Where are you doing this?
Hey, I think I understand, I think, I'm trying now, maybe if you can send me some examples of how you do it?
instead I tried to make a pattern of hexagons I put in the center of the hexagon a circle and a point where the stone was placed but then when I slide it on the surface is a mess.... the space for the griffe let it? I still don't know where they'll send me I have to do the interviews anyway it will be a company.. .
