grasshopper plugin
  • Thread starter Thread starter Sokak
Sokak
hi, I've just discovered this plugin with huge potential and would like to try to exploit it in my field of work.
I'm trying to figure out something by following tutorials and reading guides but I'm not hiding that I'm pretty hostical.
Do you have any guidance to recommend?
Starting from something simple I would like to draw two circles, to be able to define the radius, to move one along the z axis, to tilt it of a certain value and then to create a surface between the two that changes to the range of the two circles. Can you help me?
with some extra videos I managed to do what I wanted.
But I have a problem with the rotation of an object. inserting a value for example of 10 degrees inclination, the object is rotated much more. It seems that there is no correspondence between the input value and what happens.
I also have another question: how do I select or modify curves and surfaces created in boldhopper on rhino? I have no way to select them.
to perform a rotation using as a measurement method in degrees you have to use in "radians" component that converts the measure from you indicated in radiant the measure that is used for angles from gh
for selection I know that you have not yet generated objects, in practice what you see in gh colored in red or green is only virtual to make it real click with the dx button on the component that interests you and then with the left button on the command "bake"
