murdoc
Hello, everyone! for work I must verify what kind of tensions and deformations occur during the bonding of a laminated glass. I'll explain better. the laminated glass in examination and composed of two identical plates (curve) glued together with a thin film (film). when I go to paste the two plates the lower side of the upper plate will have to "combat" with the upper side of the lower plate; As the two plates identical the two sides in contact can never match perfectly as slightly different. there will therefore be small deformations in the two plates. to analyze these deformations and tensions I thought to create a set composed of low glass, with already glued the film (shaped correctly on the inner face) and place the glass above the contact with the lower glass. at this point binds the lower glass and I impose that the upper glass "comes" until touching the film; during the downhill phase the two glasses deform up to match.
I would therefore like to know which module is best to use to do this simulation.
