grey part in catia v5r20
  • Thread starter Thread starter lucadileta
lucadileta
Hello, good evening to all, I would like to ask you something that will surely be trivial; I've been using for a few days catia v5r20 and I've noticed that sometimes something strange happens, after making changes to sketches for example the part that I'm modeling becomes dark gray and I noticed that the wheel command turns off, someone ever had the same problem? in any case thanks in advance to the users of the forum.
you probably have inadvertently touching with the maus a 'stick in the logical tree. when it happens you can only enlarge the logical tree and not the component. this option you can also turn off tools -> options ... or go to select the white axle system on the bottom right
Thanks a lot! I just couldn't figure out what I was going to touch, can I ask you another question? according to you what level of knowledge of the program you can achieve by completing all the tutorials of all environments of catia v5? would be a good base?
Thank you again!
:smile:
you can reach a high theoretical level.
but without practice I see it hard.
by practice I intend to really work with cv5 and compare as much as possible with the daily problems.
If you have to change a small radius and the vaquasi tilt system forcing you to redefine the model here is where you will learn to intuition I would dare say the "fines" of the system...
Let's say that more quality files you'll create and more things you'll learn.
In any case, more tutorials will complete and theoretically easier you should be.
example: I did the course gs1 2 times but if you don't use it daily or almost never, I don't need much. in fact when I have a file with annaspo surfaces.
I hope I helped you.
ps: complete all the tutorials sgnify also spend a lot of money. What could you use the piping module if you don't use it?
In fact as I imagined, the tutorials give the knowledge but only the practice securely fixes them in the baggage of skills, I will carefully choose what to do :-), can I ask you something? I read you're in Switzerland too, can I ask you in which area? I am in the canton san gallo, hello and good evening!
