grezzo compound
  • Thread starter Thread starter meacmae
meacmae
I have this kind of problem.
I have to achieve a control caliber for a twisted shape.
My problem is that they are in z with a lot of variation if I create a single rough I have to work it very much, while I for the construction of the caliber I mount 2 blocks one a parallelepipedo (400x120x40) and a cube superimposed with dimensions (40x50x30).
I avoid so much fresare, but I can't build this initial rough on featurecam, and it seems impossible that the prog. can't do it.
Who can help me?
hi, in featurecam you have the possibility to automatically define a rough as parallelepipedo, cylinder or polyhedron, intended as an extrusion of a regular polygon.
for different forms you must select the rough user option and then select raw solid to be able to select one.
this can be either a solid imported from an external cad or molded into featurecam (but you must have purchased the 3d modeling module).
if you have neither a cad nor the internal module, then you can first create a parallelepiped block of total dimensions (400 x 120 x 70 in your case), cut off the material around the block on the first 30 mm, simulate the removal and then save the simulation in a stl file.
at this point you can start with your work by uploading and defining as a rough user the stl file.
ah, to save the simulation as stl, the command finds it under sight -> simulation -> saves simulation results.
I hope this will solve your problem.
