grenatopc
Good day to all. I often get to do holes with the sinking of 1 mm. now I have to make a cylindrical hole first, then a hole with the diameter of the deep spool 1 mm with angle of 90 degrees concentric.
Does anyone know if there is a way to make the above hole in a single passage?
other more or less pertinent question: what difference is there between the laminated hole and hole with lamatura? (second and third option per hole type)
Thanks again for the help.
