hand insertion chart values of together
  • Thread starter Thread starter davide_pontini
davide_pontini
Good morning.
I have made maps for various formats to be used in case of welded compounds\pastes\plants.
the columns report various fields, of which the last is the cut, quantity to be inserted by hand that reports the amount of material to be prepared to obtain the particular.
Unfortunately, in case it has more components within the axieme, as I did the table, (composed by one line in the format that becomes multiple rows as I add the parts), I can edit only the first row and all other cells become equal.
to have different types of hand editable cut I have to pass by a parameter or there are repeat region options that I can use to "swin" the lines that are generated compared to the first one that commands^
thanks to the answers
Hello, David,
my experience is limited to program versions prior to the creo: I do not know any command that gives way to unleash rows or columns or cells in repetition regions.
I also use the "repections" tables to present a tube cutting table or aluminum profiles but all their lengths are "winked" and calculated automatically.
Hi, I'm trying to answer you.
in the table add a new column under table->Add column.
later in repeat region ->commenti->def cell go to select the newly created column.
I forgot...
the insert values are "comments".
I avoid using them, rather I do as moreno100, I create a parameter in the parts.
Be careful! ! ! !
I quote on trying to avoid comments in the tables with region repetition (they are lost if by chance you suppress a component and regenerate the table and then saved).
a parameter defined by user is always better than this.
if then the comment in question, corresponds to a calculated quantity from the program, you would do even better to make everything to him.
