squiddi
Hello everyone, it's not long since I use abaqus and I need some expert help. my model is formed by a beam that flows within a guide; between the guide and the beam there is a distance of about 0.2 mm. the beam should not go out of the guide but it is free to move in every direction (guide and beam have slightly oblique sides so that the beam is stuck inside the guide and can only slide). My problem is that I can't bind the movement of the beam within the guide. I tried using a hard contact interaction between the beam walls and those of the guide but, as soon as I hang a load, the beam penetrates the guide as if this did not exist. How do I use hard contact when I have two bodies that are not in contact?
p.s the guide has this form /_______\ and the beam gets stuck inside it so that it can not go out but only scroll. I applied a hard contact between the superici oblique driving and beams and between the lower surface of driving and beams.
I hope I've explained well, thank you very much
