Peppe.Giuli
Good evening community,
I am struggling with the choice of a heat exchanger (balanced plates or inspectable plates) for a cooler, after performing all the calculations of the case I have arisen a doubt about a temperature that at the moment I hypothesized (and I hope to calculate the correct value! )
I attached an image to be more understandable, inside the cylinder in aisi 304 of diameter 1400 mm I find of the material at the input temperature of 110°c and I would like it to cool up to 50 °c, through passage of water between the diameters 1420 and 1444 mm (t= 20°c and flow of 35 mc/h).
on the warm side, I hypothesized a water input temperature of 80 °C and exit at 50 °C but this follows that I have a high deltat and I have difficulty with the balanced models.
so I ask, how can I verify the temperature of the water in contact with the wall (is it right to consider it equal to 80°c)? hypothesize an average value is correct? how to calculate the water temperature in contact with the wall for heat transmission?
thanks for the answers
Giuseppe
Giuseppe
