heavy bookcase objects
  • Thread starter Thread starter gianlucapapi
gianlucapapi
Good morning to all, I am making an interior design (kitchen room) and I downloaded from the website archibaseplanet.com of the objects to load in the archicad13 library. All right if not, they turn out to be too "heavy" and when I go to launch my 3d (simple ) lines removals, no charge more, 0 very slowly.
What do I do? Is it my little powerful pc? or the objects I found aren't the right ones for my program?
and if so you would know how to advise me on: less heavy objects and where can I find them?
Thank you very much. hi good work.:wink:
see if the site of the objects you downloaded, from indications of the characteristics of the pc for use ...
It is a common problem and due to the fact that archicad objects are converted from other formats (typically 3ds) and in conversion each curve generates hundreds or thousands of small triangular surfaces. there are no direct solutions, especially with archicad 13. you should look for objects created already in native format (gdl).
