Ompu
I'll give you my problem.
I have to create a helical scale in revit, of course through the boundary scale command. I saw the impossibility of creating forms of ellipses with such command, and therefore I created it through numerous arches at 3 points.
But my problem is in the railing. I would like a continuous tubular handrail that follows the profile of the scale (a 3d helical spline, we say), but I get this type of discontinuity, even changing the connection type of the joint.
I then thought of creating it with a local model, but I can't find the way to create a route extrusion with a 3d path (a 3d propeller for precision).
I also have the problem that I would like to insert glass balustrades that partially follow the curvature of the section in which it is positioned.
could you explain to me the correct way to create this railing (or how to shape it in solid? )
thank you very much for the availability
