tatekan
Hello everyone, I would like to introduce you to my problem:
I designed a small object in autocad and turned it into artlantis object so that I can change it/move/color according to my needs. I will explain to you the procedure I have applied:
just open artlantis, I load my design cad and, then I go to files and "export as object"...., I save it inside the artlantis/media/object folder and up here all right.
when I go to apply this object created in another artlantis file (for example in a vertical wall) does not normally insert it as all other objects but much further away. going to activate the object key, known that the blue ball (which would allow me to adjust the position of the object) is very moved compared to the object itself. For example, if I insert a chair, by clicking on the object button, above the chair itself (in visual 2d) there is a blue ball that allows me to position the chair where I want. in the case of my object created instead no...., please tell me where I'm wrong:frown:
Thank you very much
Thank you very much
