help by command "unit" full version vs. lt....
  • Thread starter Thread starter PiroPiro
PiroPiro
Hello everyone,
I'm brand new and I'm asking for your help... :
I spent a few days at the full version of autocad 2016-2017, before I had always worked with various versions (starting from 2006) lt; with the current version I can not set an angle 0 starting at a point, along a defined line.
with lt it was enough to use "unit" and click on direction, set the base point and then the direction from which to start on which to set the 0 angle
e.g. :
command: unithttp://help.autodesk.com/view/acdlt/2016/ita/?guid=guid-2682959e-e66e-4381-a223-d2204aa2267adirection dialog box:http://help.autodesk.com/view/acdlt/2016/ita/?guid=guid-2682959e-e66e-4381-a223-d2204aa2267ain the current full version, there is no more the "direction" button... and I can't, if I don't manually calculate the angle, set it.. . .
Is there a solution, shortcut and/or command, set something to solve the problem?
thanks in advance
Matteo
