help creation cocreated cartilages
  • Thread starter Thread starter fabiovello
fabiovello
hello to all boys,
recently I use cocreate and I lost myself in the table, I would like to create a custom paper cartilage and a square with possibility of autocompilation, someone can help me? :confused:
Do you use any pdms?
Even if you didn't specify it, I think you're talking about annotation and not me10.
if you open the annotation configuration file the cartiglio is here:
(docu-register-frame :ui-name "a0" :wm-name ") :file "<unita>:<percorso>)
I edited them with me10, I hope you own it.</percorso></unita>
I use one space modeling 2008 16c to what do you mean when you talk about m10?
sinceramante I found files with *.mi extension but if I change them then I can't pull them up.
I modified them with cocreate drafting 2008, saved in the folder where there are others, extension *.mi but nothing to do sees only his.
I'm just a jug.... Sorry.
ok drafting = me10 (it's the same thing)
Are you sure you've taken the carts that he loads?
I think you're changing others.
to be sure try to use filemon
(www.sysinternals.com)
It is a bit rough as a method but it works ;)
but the path is what you marked me in previous posts?
Now I found them... Is self-compilation hard or feasible?
Yes.
say that usually in the file (PHP 4 = 4.1.0) there is the set for the cartilians(PHP 4 = 4.1.0) which should be in a folder like this:c:\programmes\cocreate\onespacemodeling1650\personality\italian\sd_customize\annotation\
you have to add an info to the texts you want to autocompiline:
For example:
for the scale:tr:sheet_local:sheet_scale:2:0:1:-102:1:0.for the number of exemption:tr:sheet_global:drawing_no:2:0:1:-102:1:0
Thank you! I found the percosis and also the autocompilation is fine, I can not only automatically fill out the fields location and quantity from me 3 question points.. I might ask in assistance.
What about the tables? I have an installation on the server and I'm editing files... Do you know anything about that?
it is distinct base, for now I have managed to change it using the commands but I can not create my own
Yes.
say that usually in the file (PHP 4 = 4.1.0) there is the set for the cartilians(PHP 4 = 4.1.0) which should be in a folder like this:c:\programmes\cocreate\onespacemodeling1650\personality\italian\sd_customize\annotation\you have to add an info to the texts you want to autocompiline:
For example:
I wanted to ask you how to insert pos. and q.tà automatically? I found the info, but the three question marks appear, is there any procedure to follow?
I created a semi-automatic compilation menu of the cartilage. . .
in the sense that I insert the values in my menu and fill out the cart. .
The possibility exists, but I'm a little hard to explain. - Because he's a little sniffy. . .
but excuse me, do a day of course where you solve all your problems??
I think you do first and better....they cost expensive, but if you count all the hours you lose to learn you will see that then the recoveries;)
the course I did and finished and now I no longer have problems only that I was anxious to do alone and I managed it thanks to everyone!! !
hi to everyone, I just registered at the forum that I find very interesting.
I just started using autocad 2009, specific which is the first time I work with autocad, someone would have the patience to explain how to create a cartiglio?
hello to everyone and thank you in advance.
