kikkolo81
I have a problem with custom defaults in nx8 with windows 7.
imposed parameters from file\utility\default_personalized and saves everything in a file c:\users\user\appdata\local\unigraphics solutions\nx80\nx80_user.dpv
the problem and that at the next opening of nx8 does not charge the parameters set in default, why?
in old versions with win xp I set the file ugii_env_ug.dat:
ugii_local_user_defaults="${userprofile}\local settings\data application\unigraphics solutions\nx4\nx4_user.dpv"
while with windows 7 (not having documents and settings) what path to set?
